Gázolaj árak 647 Ft Benzin árak 628 Ft EUR 413.74 Ft USD 403.55 Ft CHF 440.33 Ft GBP 492.37 Ft
John Deere 4630 traktor hazai története
Létrehozta: Bolhóieke , 2008-03-04 15:17:01
2239 hozzászólás
#589 jd /4650
2009-02-19 21:31:32
na ez az
#588 jd /4650
2009-02-19 21:30:37
Válasz #587. hozzászólásra
MANUFACTURED BY:
STIHL ANDREAS MASCHINENFABRIK
STUTTGART, GERMANY
SERIES OR ASSEMBLY NUMBER:
1115
YEAR INTRODUCED:
1974
YEAR DISCONTINUED:
ENGINE DISPLACEMENT:
75ccm (4.57 cu. in.)
NUMBER OF CYLINDERS:
1
CYLINDER BORE:
50mm (2.0 in.)
PISTON STROKE:
38mm (1.52 in.)
CYLINDER TYPE:
Aluminum with chrome plated bore
INTAKE METHOD:
Piston ported
MANUFACTURER ADVERTISED H.P.:
WEIGHT :
8.4kg with 33cm bar & chain
18.48 lbs. with 13 in. bar & chain
OPERATOR CONFIGURATION:
One man operation
HANDLEBAR SYSTEM:
Anti-vibration
CHAIN BRAKE:
Optional
CLUTCH:
Centrifugal
DRIVE TYPE:
Direct
CONSTRUCTION:
Die cast magnesium
MAGNETO TYPE:
Bosch (Thyristor electronic ignition)
CARBURETOR:
Tillotson HS-118B series
MAJOR REPAIR KIT:
RK-21HS
MINOR REPAIR KIT:
DG-3HS/T
AIR FILTER SYSTEM:
Wire gauze element
STARTER TYPE:
Stihl automatic rewind
OIL PUMP:
Automatic
OPERATING RPM:
IGNITION TIMING:
2.7mm (0.108 in.) before TDC
BREAKER POINT SETTING:
none
FLYWHEEL/COIL AIR GAP:
0.2 to 0.3 mm (0.008 to 0.012 in.)
SPARK PLUG TYPE:
Bosch WSR6F
SPARK PLUG GAP:
0.5mm (0.020 in.)
CRANKSHAFT MAIN BEARINGS:
Ball
FUEL TANK CAPACITY:
820ml
FUEL OIL RATIO:
40:1 with Stihl oil
RECOMMENDED FUEL OCTANE:
Regular
MIX OIL SPECIFICATION:
Stihl two-cycle chain saw mix oil
CHAIN PITCH:
3/8 in.
CHAIN TYPE:
Stihl
BAR MOUNT PATTERN:
SHORTEST GUIDE BAR SUPPLIED:
33cm (13 in.)
LONGEST GUIDE BAR SUPPLIED:
50cm (25 in.)
COLOUR SCHEME:
Grey with Red top
#587 JD 4630
2009-02-19 21:13:54
Válasz #586. hozzászólásra
És a mororja?
Én is 45-50 körülit használok a 285-ösre.
#585 JD 4630
2009-02-19 21:11:01
Válasz #584. hozzászólásra
Akkor az mág bejáratós :-))
#584 Paldoo.
2009-02-19 21:10:17
Válasz #582. hozzászólásra
Enyém még gyerek.
Csak 9.
#582 JD 4630
2009-02-19 21:08:44
Válasz #580. hozzászólásra
Sok, kb 20, de tavaly újjászületett, azóta nagyon harap. :-)))
#581 JD 4630
2009-02-19 21:07:40
Válasz #579. hozzászólásra
Van 1 20-as stil is csak szervizben van, talán jövő hétre meglesz, ha megjön az alkatrész hozzá.
#579 jd /4650
2009-02-19 21:05:59
Válasz #578. hozzászólásra
nekem sthil AW 043-van
amire kell elegendö nekem
#578 JD 4630
2009-02-19 21:04:33
Válasz #576. hozzászólásra
Csak dieselre vagyok hitelesítve, a benyás gépekhez hülye vagyok.
#577 JD 4630
2009-02-19 21:03:37
Válasz #575. hozzászólásra
H 285 -ös a karbi és a henger között törnek a csavarok mikor melyik, meg most a szivattyúja is egyre kevesebb olajat visz.
#576 jd /4650
2009-02-19 21:01:50
Válasz #574. hozzászólásra
ismerös
milyen tipus a fürész
ti ebben profik vtok tuti
#574 JD 4630
2009-02-19 21:00:46
Válasz #573. hozzászólásra
Ez ismerős. Én mostanában erdőt vágok, de már kezdem unni, meg a fürész is egyre több ször kell azt is generálozni, valami mindig sz*rekodik rajta.
#573 jd /4650
2009-02-19 20:58:53
Válasz #571. hozzászólásra
alakul széppen csak van más is állandoan
#571 JD 4630
2009-02-19 20:58:03
Válasz #569. hozzászólásra
Hogy állsz a lazítóval?
#568 JD 4630
2009-02-19 20:36:10
Válasz #566. hozzászólásra
Bocs a SZIA! kimaradt.
#567 JD 4630
2009-02-19 20:35:12
Nálam sem kattan és a 30-asom hidegben sprével idul, pedig felújított motor, igaz adagolóból nem kapott felújítottat.
Mekkora a gyártási száma?
Hol szerezted?
Fotod van?
#566 Zoli
2009-02-19 20:24:39
Heló mindenkinek, vettem egy rossz állapotú 4630-ast és van egy-két baja, hogy példul a dúsító nem kattan, meg füstöl is egy kicsit, de főleg a dúsító érdekelne, mert nehezen is indul, gondolataim szerint emiatt, aki tudja esetleg, hogy ott mi van benne, mi lehet a baja és hogy lehet javítani, vagy esetleg tudna küldeni egy képet katalógusból róla, hogy-hogy is néz az ott ki, azt megköszönném, e-mail címem: gepkereso@citromail.hu előre is köszönöm mindenkinek aki tud segíteni!
#565 K.Pisti.
2009-02-05 21:29:18
Válasz #562. hozzászólásra
Andika szőke vagy , vagy csak úgy () izé ???
NEM NEKED IRTA AMIT IRT ()()
#564 Jani X
2009-02-05 21:27:12
Hú!
Most nem lennék a helyedbe!
#563 Fan
2009-02-05 21:26:46
nem rád gondolta
#562 Katonane Kiss Andrea
2009-02-05 21:25:03
Válasz #557. hozzászólásra
bocs hogy így felizgatott de megírtam hogy ma regisztráltam és nem tudtam hogy működik a fórum.egyébként ismeretlenül sem kellene sértegetni senkit,mert erről mindenkinek megvan a véleménye!!!
#560 K.Pisti.
2009-02-05 21:01:32
Válasz #559. hozzászólásra
nem, katonánéandika irt mert rákattintottam a moderátorra és ....
#558 Paldoo
2009-02-05 20:59:19
Válasz #556. hozzászólásra
Itt meg mi volt?
#557 JD 4630
2009-02-05 20:40:58
Válasz #546. hozzászólásra
Megkérnélek fatökű "barátom" szórakozz máshol, ha már érdemben nem tudsz a témához szólni. Ezt a topikot nem az ilyen hugyagyú babmok kedvéért nyitottuk, hanem hogy egymást segítsük.
#556 Moderátor
2009-02-05 16:20:42
2009-02-05 17:43:51
#554 K.Pisti.
2009-02-04 23:38:44
Válasz #553. hozzászólásra
Há pedig rohadt egyszerü, nemúgy mint a Zetoré
#553 Jani X
2009-02-04 23:36:08
Válasz #551. hozzászólásra
Bmeg, én ezeket a számokat keverem, min állat, meg se próbálom jegyezni :))))
#552 Paldoo
2009-02-04 23:35:30
Válasz #547. hozzászólásra
Biztos a tied ez koma?
#551 Géza
2009-02-04 23:30:04
Válasz #550. hozzászólásra
nem, de rámozdult a múltkor 4650-re
#549 Géza
2009-02-04 23:27:04
ez durva volt!!!!!!!!
#548 misike
2009-02-04 23:22:22
Téged nagyon szeret valaki itt a fórumon!
#547 majomparasztgyirik
2009-02-04 23:22:20
ja , az imél címem
csaszibela@gmail.com
köszönöm
#546 majomparasztgyirik
2009-02-04 23:21:10
Ide irjon az akinek van alkatrésze Jonn díírhoz, főleg 4650-eshez kellene sok minden .
#544 Zoli
2009-01-13 20:53:23
Egyelőre köszönök mindent, ha valami gond van akkor még jelentkezek. Szia
#543 JD 4630
2009-01-13 20:34:24
Válasz #542. hozzászólásra
1 fajta hüvellyel vannak szerelve, de az nem 105 azt hiszem 4,25-vagy 4,75 colos, az egyik a furat a másik a löket.
Az olaj szerintem nem biztos hogy a kormányműből folyik(lehet az is de nem volt még vele gondom), általában inkább a fölötte lévő szivattyúról csepeg rá(nálam a résolajvisszavezető volt tavaj amelyik engedett).
240bár a 4630
290bár a 4650
#542 Zoli
2009-01-13 20:24:17
Válasz #540. hozzászólásra
A gazdája mondta, hogy 105 a benne lévő hüvely átmérője. Van egy olajfolyás azon az öntvényen, amiből kijön a kormányrúd, ott van valami minkahenger vagy ilyesmi ami forgatja a kormányt, vagy mitől lehet az a folyás? Köszi a telefonszámot
#541 JD 4630
2009-01-13 20:14:45
Válasz #539. hozzászólásra
Tel.: 06203317583
#540 JD 4630
2009-01-13 20:12:49
Nem élek mnssel :-(
A kartergáz ha csak kicsi jön az nem gond.
Hogy érted hogy 105 a hüvelye?
Porlasztónyomást fejből nem tudom de megnézem, 2 fajta porlasztófuvóka van 3 és 4 furatos és arra sem emlékszem hogy azonos nyomásra kel e mindkettőt beállítani.
Egy virág, ami rezisztens a glifozáttal szemben
A magasabb szintű glifozát-rezisztenciát mutató növények a rovarokkal szemben is...
Sok a bizonytalanság a repce körül
Nem túl jó kilátásokkal indul az év.
EXKLUSIV 3500 rendsodró
580.000 Ft
Bogballe M2WD
Bogballe M2WD
4.000.000 Ft
215/70R16 LINGLONG ÚJ 4 ÉVSZAKOS GUMI AKCIÓ
215/70R16 LINGLONG ÚJ 4 ÉVSZAKOS GUMI...
27.500 Ft
John Deere 6110MC - 0%Áfa-Leszállítva
18.900.000 Ft
